My 99 Duelly with 235 CTD started to do a momentary jerk like you had cut the Ign. Switch off and back on real fast. It has no set time to do it-only when it wants to. It don't matter if it is loaded or not. We where pulling a 20' Haulin Car Hauler. We had to go from Al. to Co. and back to pick up my wife's bike and it started this on the way out there. After we got back-I carried it to a local Diesel Mechanic I know and he run a scan on the truck. He said it was the Crank Sensor Code that showed on his scanner.
My Question Is--Is there any way to test the Crank Sensor to see if it is really bad or if it could have been a loose connection that caused the jerks and the Code to be set? If anyone has had this same problem-Please let me know what you did to check it and to fix it.
THANKS::BHerndon
THANKS::BHerndon
