Should you be able to see oil vapors coming from the crankcase breather vent? While idling, if I close off the tube with my thumb for a second and then release, I get a blow of vapor that you can feel five inches away from the tube outlet. Does this sound excessive? I noticed this when investigating a drone that just started at idle and around 1600 - 1800 rpm. At idle, the sound seems to build up and then down repeatly. It seems to be emanating from the oil pan area, but I'm not 100% sure of the exact location. It’s as though something is resonating.
I'm new to diesels and am not totally familiar with the sounds that should be expected, so I investigate sounds that have changed. This is definitely a new sound, and I haven't noticed the oil vapors before. I have checked the crankcase breather tube before and the ID always seems dry.
