Originally posted by Dieselgirl
P. W.
When Starting , The motor turns 10-20 revolutions before it starts. Barely puffs out smoke. Don't even smoke hardly anymore. Before I got the injectors done. It would puff out big puff of black smoke But not now. When you get on it, It don't smoke like it did, Before the injectors were put in. My pump is turned away from the block as far as it goes.
Do you know which way you tweak the pump?
Amy
93 D350 Club Cab Le
Wow...
Let me give you my best shot at it. To give you some background: I worked in a fuel injection shop for well more than a dozen years, I did some work on the very model injection pump on your truck, and I did quite a number of installs and some tweaking.
Normally: the idle is set with a set screw on the backside of the pump. It is generally set right on the test stand when the pump is rebuilt, and is usually within 50 rpm of the specification, even though there is a range of fuel allowed at that speed.
IF you crank up the fuel, it moves one of the associated governor parts and will generally INCREASE the idle slightly. If you get radical with the fuel screw, it will make a definite difference in the idle speed.
Normally, your pump's position is such that the top diaphragm housing is a man's finger width distance from the edge of the cylinder head. My truck, which is slightly advanced, has sufficient room to get my index finger in the narrow way, but not the wide way. This is not an accurate measurement, but vehicles are sufficiently consistent from engine to engine for it to be generally meaningful.
The fact that your truck now starts slowly, and puffs out only a little bit is probably indicating that they turned your fuel down AND retarded the timing. The fact that your pump is rocked all the way away from the engine in the slots would lead me to guess that they did try to set it, but perhaps left the bolts loose? The timing being that far retarded would tend to inhibit starting quickly, as there simply would not be enough heat to fire immediately.
Does your truck smoke blue when cold? It should not. That, too, is another symptom of retarded injection timing.
I don't know who did the work for you, or anything about them, and not wishing to slander anyone, I can only say what appears to be...
Also, the fuel setting screw comes out of the back of the pump, a little to the block side center, about the level of the idle and max speed stop screws. It has a big metal seal over the top (normally). From the factory, it has a spot-welded collar over it that prevents you from turning the fuel up. If this collar is there, the screw should be in just as far as it will go against the collar and locknut. It really sounds like someone backed it way out, as well. Anyway, I wish yer truck was nearby, as doing this is far too difficult over the internet. There's just too many nuances and whatnot to be very accurate.
