First time post here. I have been a TDR member for about 2 years, and have read a lot of post, very useful information. I have never had a need to post until now.
I have a 1990 W250 with 225000 miles. Truck is all stock except for the muffler removal and radiator update. Truck used to start as soon as you hit the key no matter what temperature. Now when the truck sits for more than an hour it will turn over on the starter 15 or 20 times and sometimes I have to press on the pedal to get it started. It's only in the 70's here now so its not related to cold temperature. Runs great once it starts, plenty of power, idles fine, etc. I changed the fuel filter and bled the low pressure side for air. It did seem like it had a little air but not a lot. I didn't bleed the injectors, because it runs fine once it gets started. Any suggestions on what I should try or my problem.
