Crankshaft Pos. Sensor
Hello and questions....
Truck order time?
What symptoms if any did you have when your Crankshaft position sensor acted up or stopped working??? I haven't had any real trouble except for a a feeling like something is tugging on my rear bumper at low rpm and a tach needle that isn't that is kinda jumpy.
ran like sh*t, check engine light came on.
99 2500 4x4 QC Std transmission, Puple, 10 Disc Sony Changer, 285x75Rx16 BFG Mudders, Gooseneck hitch, 275lb King Klaw front bumper, Towing/Camper setup.
1965 Chevy 1/2 ton Pickup, 350-350hp/2spd powerglide, PS, PB, Disc Brakes on the front, Tilt, Fuel Cell, 3. 73 posi.
26ft Gooseneck Flatbed Trailer.
1960 Farmal 340 Diesel Tractor
Keith,
My engine stumbled and the tach fell to zero then it came back to life. Did this two or three times over the weekend before I found a sensor. I confirmed the problem by having Chrysler put the scan tool on it.
243
99 QC 2500 ST 4X4 SB 24V/5speed 3. 54/LSD Driftwood/Agate
Walker 21468, VDO, Bridgestone 285/75/16 MT's, RS9000's, Hella 500's
http://www.0hassleisp.com/dwilk/243'sRamPage.html
-- email address removed --
I had a cranshaft pos. sensor and boost sensor go bad at same time. Loss of boost sensor caused a big loss of power the crank sensor caused the tac to go dead.
On some crank position sensors (not sure about ours... maybe) you can simply pull them out and see where the moveable plastic piece has sunk into the sensor too far. If you pull that plastic piece back out and slowly screw the entire sensor back in, it might work for you again. Might be worth a try. Hope this helps some.
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, EZ box, race transmission, Barry Grant fuel system, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member
My Diesel Page
Hey Chad, I noticed that it looks like you have to remove the starter to get to the sensor. Is that right or can you work around it?
Thanks
Kieth were you aware that Parts Plus and Advanced Auto will let you rent a scan tool for most any application. all you need is a deposit down for the cost of the tool ($300) but you get it all back when you return it. i used one to diagnose transmission problems on my 95 set it up to constantly monitor AIT CPS and TPS while driving. used it for three days and returned it for all of my deposit.
Todd,
2001 Q-cab SB 4x4 5spd 3. 55's, A pillar Boost/EGT,Jardines 4" turboback kit, and more to come...
Keith,
Do you have the sensor?
I had major problems finding mine and eventually it was a Chrysler dealership that had it. I may have the original and the new box with the part number, I will go look for it.
243
On trucks manufactured after 7/00, the crank sensor is omitted and uses the cam sensor held in by one allen screw in the front cover under the injection pump. You'll know which design you have if a scan tool shows "no cam signal" but the crank signal is fine. They didn't take the crank pulse line out of the ECM's reader side, which makes it confusing if you didn't know the crank monitor signal map was removed... T
