i have waited about a year now to purchase a very clean 93 one ton from the original owner. it has about 100,000 easy miles, extended cab, auto. recently the owner heard some type of noise from the transmission area and brought it to the local ford dealer. this is a small town, no dodge dealer. i personally know the mechanic who worked on the truck. what was found was that the thrust bearing was worn enough to let the flywheel contact the block, hence the noise. has anyone ever heard of this on an engine with what i consider to be low milage? they are going to change the main bearings and the flywheel. any info or opinions welcome. thanks in advance.
