Crazed Light Switch
7:30 Wife arrives home in her rig, with dinner, says lights are goofy!
7:40 Finish dinner, check truck.
8:00 She’s right!
8:15 Log on TDR
Here’s the deal, this is an 04 with fogs, see sig. Start the truck, haven’t touched the light switch yet but the fog lights come on. Turn the light switch to the park position, seems normal – no headlights and the fogs will come on when you pull the switch out. Turn the switch full right (should be headlight position) and … nothing, the only way to get the headlights on is to pull the switch out to the fog position and then the headlights work, both high and low beams correctly but no fogs at all! Here’s the clincher – turn the headlight switch off, shut the truck off and the fog lights come on, then after a few minutes they will go off, I suppose through the timer. As far as the parks go, I think they are on anytime the truck is running and like the fogs go off only with the timer after shutdown.
No, I’ve not had a drink and didn’t make this up. Any one seem this before or have a suggestion?
Thanks
8:00 She’s right!
8:15 Log on TDR
Thanks
