my 95 developed a leak at pitman arm shaft. it works well and the shaft does not move around. so i took off the pitmam arm off and bought a seal kit. i went to take off the snap ring and there was a seal there, i was beffudled, so i took out that seal and found the snap ring and washer. i took off the snap ring and the high pressure seal came out under pressure while turning wheel. i have had the truck for 80 thousand miles. no leak, and i could not understand why the dust seal was on the outside of the snap ring like it was, so i put in a new seal kit and there is not enough room for all the seals and washers so i can't get the snap ring to seat. i am sure the previous owner found the same problem and that is why the dust seal was on the outside of the snap ring. it seems to me that the bearing moved down a bit causing this problem. but the box is in fine shape mechanically. has this ever happened to anyone and what should i do. i realize the box should be replaced but i have heard alot of bad things about replacement boxes. i am going to try the same fix again i. e. put in the high pressure seal and washer and snap ring and just put the dust seal outside that. the pressure seal i took out was in bad shape, so maybe i have a chance. but this is a very weird situation. any input would be greatly appreciated.
