Creaking Accelerator Pedal?
DRW to SRW Conv?
Thank you Kent Kroeker.... DW is really gone.
My accelerator pedal has started creaking like an old hardwood floor. It's driving me nuts. Has anyone else experienced this? Anyone have a fix?
I should probably not try and push it through the floorboard on a regular basis...
Thanks,
Andy
Yep, mine does it too. I haven't gotten around to trying to fix it. I think it's the spring on the backside of the pedal (I'm pretty sure there's a spring that keep the pedal from flopping around). I'm thinking a shot of some lube or grease might clear it all up.
Mine went through a spell of that and fixed itself before I got around to it. It was REAL annoyin' while it lasted, though. I'll be watchin' for solutions in case it comes back around.
I know, I know, I should stay where I belong (2G forum)
Mine just started to do it. If I can remember when I have the time, I'm going to crawl under the dash w/ a can of spray lube & hit all of the moving points on the petal I can find.
Hope this helps.
~Matt
I've tried spray lube all over the back of the pedal. So far that hasn't helped. It's been about a week since I tried that. :(
I might try disassembley.
