A customer of mine is working on a 95 2500 Diesel that under light brake pedal pressure the pedal goes to the floor, but never loses any fluid. The owner put two master cylinders on, but the problem cotinued. My customer started from scratch, replaced a leaking rear wheel cylinder, rebuilt the front calipers, replaced the front & rear hoses, bled the system, but the problem continued. He then replaced the master cylinder with a new one, but to no avail. He then started going through everything again & found if he blocks off fluid to the right front caliper the problem disappears. He tried blocking fluid to the other wheels, but the problem continued. Being a fairly simple system, he is lost as to what to do next.
