This is for my TDR friends that don't follow the Conversion forum very often. After much delay my 85, Dodge of course, D350 crew cab is now Cummins powered
. The engine and transmission is in, minus drilling new bolt holes for the diesel transmission crossmember. I know some conversions were able to use at least one set of the gasser trans crossmember bolt holes. Not this one, not even close. Originally was a 360 np-435 4 speed 2wd, now Cummins getrag 2wd. For the life of us, we could not get the engine and trans, bolted together, to clear the cab and engine crossmember. The bellhousing was hitting the cab, and the forward end of the oil pan was hitting the engine crossmember. No matter what angle I had the combo, was using a cherry picker and load leveler, just wouldn't make it. Even with a jack underneath the trans it wouldn't go. After about the fourth attempt me and Matt removed the transmission and the engine slid right in. This was with the radiator core support removed too. Sorry no pics right now:-{}.
