2nd Gen Non-Engine/Transmission Cruise Control Indicator
Engine/Transmission (1998.5 - 2002) Oil Analysis
2nd Gen Non-Engine/Transmission Need Intake Hose.. Got an Extra one?
My cruise control indicator has stopped working. The light does not come on either during the lamp test when the key is turned on or when the cruise button is actuated. The cruise control itself works fine.
I have looked through the service manual and I cannot figure out if this is a replaceable bulb or not. Does anyone know?
Thanks.
Lucky you - I have just the opposite problem. "Cruise" indicator light comes on but cruise control doesn't work.
Did the trouble shooting from the service manual - I have vacuum to the speed control servo and all of the servo electical checks out but still no workee! Looks like time to go to the stealer.
Kev
Kev, your servo may be repairable. If the plastic part has holes eaten into it from battery acid try cleaning them up and covering them with two part epoxy. Worked for me:D
