Alright, now that I've got the turbine housing under control (with great help from you guys), the other item on my list is installing cruise control. I have gathered nearly everything I need and have installed the steering wheel switches and new clockspring, I have the regulator (under hood) and have connected it to the vacuum line and the wiring harness, now the question is:
How does that cable attach to the throttle linkage?? The cable coming from the vacuum-assisted regulator has a long slot on the end, and I know WHERE it attaches, I just can't figure out HOW it attaches. The shop manual is no help, and I haven't found a truck to look at (that would be simplest).
I am probably missing some small critical part (the stealer can't figure that out using their lame diagrams), but can someone describe this connection so that I can rig it up? A picture would be awesome, but anything would help at this point.
I imagine the slot allows the throttle to move normally when cruise is not engaged, and then when cruise is engaged, the cable pulls the slotted end back until it contacts the throttle and then controls it... . but who knows, I could have it all wrong.
Thanks for any help,
Jack
Jack
