I just bought a 04 CTD and I am having an issue with the cruise control. At slower speeds it works and functions fine. But when I try to use it at faster speeds it doesn't work. Has anybody seen this before, and if so, what was the fix?
Pretty sure 3rd gens do not have a vacuum any longer. All electronically controlled.
My 3rd Gen (2003) has vacuum line. Mine got terribly brittle and fell to pieces so I replaced it temporarily with some tubing I had out in the shed. It works again but I think the larger diameter tube allows the truck to vary the speed more than it used to. Anyway, at least some 3rd gens have vaccum line.
Same issue with mine. Vacuum servo chk'd w/no leaks so vacuum pump [pass. side] getting weak. I tapped into my [Banks] Exhaust Brake vacuum pump line & now plenty 'power' to pull in the vacuum servo for cruise cntl. at higher speeds.
I don't know about ya'lls trucks, but mine does not have a vacuum pump. Its all electronic
That is due to you having a manual trans and speed control. You still have the APPS under the driver side battery but speed control is all done in the ECU.
Unless you have one of the wierd hermaphrodites like mine that has it on the bell crank.
04.5 is under the battery tray on the drivers side.
Not always, some odd ball OE setups out there with the APPS on the front of the engine with a manual trans.
