Details here: TDR Privileges
cruise control stopped working . with engine running and switch on checked for ground at servo plug ok checked for power at pin 3 no power . checked continunity from pin 3 to stop light switch ok . continunity at terminals 5&6 of brake lite switch . anyone had this problem. ?
Perhaps you just changed your fuel filter and accidently pulled the vacuum hose loose under the injector pump. If this is the problem, your heater controls don't work either.
thanks for your quick help . i forgot to mention that i also checked the vac. pressure which was 26. 5 . i think the problem is electrical since there is no voltage at the servo. has anyone had a brake switch failure? the power to the servo comes from there.
