I have 97 in the shop with no cruise. I did a search but did not come up with a cure. The green light will flicker when you first turn the key on, and then once more after you turn the key off. It will not turn on when you push the on/off button. With scan tool the speed sensor works, throttle position works, vaccum is good, dont know what else to check. Any ideas.
