cruise control problen W250
Cruise control runaway
Possible Cam\Tappet issue
cruise control will lock in ok
Problen will not stay in on smooth surface not bad
Hit a couple of pot holes, don't have to be big ones it will kick out.
91 IC W250
Try putting your foot under the brake pedal and lifting up, holding the brake pedal tight over the bumps.
My truck has a weak pedal return spring. Big bumps will cause the brake pedal to bounce down, coming off the brake switch which disconnects the cruise.
I'd bet a nickle that's it. :rolleyes:
