I, like many have experienced the creeping acceleration when the truck was on cruise. It just keeps climbing. BUT it only does this in the winter?? If the temp is above 75 degrees it worked fine. I searched the forum and found this;
http://www.youtube.com/watch?v=ppcUyQZ14AE
So, I took the solenoid out per the video, sure enough one of the pistons was rusted and stuck. So I used a 600 grit paper and polished the pistons. Everything went very smoothly and went back together correctly. The pistons were moving freely, so I reinstalled the assembly.
First run, cruise "acted" like it was trying to work, but couldn't keep the truck at the speed setting. . so, I took it back apart and went through the process again to double check my work.
Back together, second run. NADA, nothing... cruise doesn't work at all??? And the cruise light (green on the wheel) will now not even stay on now?
What next? Why did it work "somewhat" before with stuck piston and nothing at all now? Any suggestions would be great as I have a 1200 miles trip coming in 3 weeks.
Thanks
Thanks
