Does it do it all the time or is it only doing it when you first set the cruise when it's cold and is steady after it "warms up?
When temps are below 70* mine will speed up for a few minutes when set. It will sometimes continue to climb 10-15 mph past the set speed. I can hit the coast button a few times and stop it and I may have to do this several times until it settles down. After it "warms up" and settles down it works perfectly. If temps are above 70* it MAY do it, but not near as bad as when it's below 70*.
Another issue I have, if I have it set at say, 60mph and speed up to say, 70mph by pushing the accelerator and then push the "Set" button again it will put the pedal on the floor! I have never let it go to see where it will stop when it does this. Since mine is a "conversion" I've always chalked this up as a glitch in my conversion.
