Cruise Control
k&n filter??
More boost the answer...re-visited
I swapped my automatic for a 5 spd. I lost cruise. Ive heard that I can jump a wire on my chassis module, does neone know which wire I need to jump?
Jeremy
Can't answere your question, but have one for you. How hard was the swap? I've swapped in 4 speeds into mid '70s Chevs, but nothing else. Gettin' a little sick of the auto. Chrysler has invented a new standard for the term slushbox. What a pile. I'll either go to a stick or DTT.
Originally posted by CumminsTurbo425
I swapped my automatic for a 5 spd. I lost cruise. Ive heard that I can jump a wire on my chassis module, does neone know which wire I need to jump?...
What did you do with the park/neutral safety switch? On a '98, one would float PCM connector #1, pin 6 (BK/WH wire). Did you ground this circuit so the starter would work?
Fest3er
Couldnt tell ya, enterprise engine did the swap a while back. If ya let me know more details about it I can try something. Ive been lookin in the FSM and I can not find much of anything on the pin connectors.
Jeremy
