Cruise control
Need recommendation
Latest Lift Pump #
Have a 1997 2500 4 X 4 with 5-spd and 60K miles. Cruise control will not stay activated. Thanks in advance for suggestions. JC
Check the brake light switch adjustment. If it's off a little the pedal bounch may kick the cruize out. Also check the vacuum tubes to the cruize unit under the driver's side battery. You may have a little drip from the batteries that eat holes in the tubes.
