Hi guys, I've got a problem of surging in the cruise control. I,ve done an archive search and done a diagnostic test of the fault codes. It flashed 5 times twice, I assume that is a 55 fault, but I can't find what that means. It doesn't go with any of the codes in the service manuel. It could mean all checks out OK. Any Ideas. I'm just starting to check this out so any advice would be good to hear.
One other question,When your air cleaner gets dirty will that cause your boost to diminish a few puonds? Boost droped from 14 max to 12 over a few months, and seems to get there slower. The cleaner is going to be replaced tomorrow, it's been 20K miles. It's paper. Going to go with the fleat guard this time. It looks much better than the Fram. and is cheaper by 5 bucks.
Thanks In Advance, You guys are great. Hope to see some 1st Gens at the Temple Tx gig in a couple months.
92 D250 5spd 3. 54 std cab, Banks exhaust,Isspro EGT&Boost gages,18cm Turbo.
67 Dodge R/T
67 Charger
98 Grand Cherokee
97 Stratus
Mopar Only Here
Tulsa 2000 Survivor.
67 Dodge R/T
67 Charger
98 Grand Cherokee
97 Stratus
Mopar Only Here
