Has anyone found a way to "desensitive" the cruise control on an '01 6-speed with injectors? Since it's all electronic, restricting the vacuum won't work.
If I have it set around 70-75, it's not so bad on hills. It will up the boost then hang there, and right as you break over the top it will fluctuate some. But most times on hills I take over manually with my foot to help the mileage out some. The part where I have the problem is when I first engage the cruise. As soon as you hit Set, it throws down a burst of acceleration then falls back to the set speed. Haven't found a way around this one yet.
So I know we've got some electrical geniuses out there, was hoping that maybe someone has worked something up for this.
