Crunch, Crunch, when turning
NHTSA invvesigats brake pull, based on 23 complaints
Bosch 275 injectors
I now have 450 miles on my new truck. 17. 98mpg on the first tank. (I have a fer piece to go tomorrow so I filled it up. )
Last Friday I had a Rhino Liner and Western nerf bars installed. Now I get a crunching noise when turning corners. It's worse when turning left.
Do you folks think it's the bars or the liner?
(Wife thinks it's the liner, I think one of the mounting brackets on the bars are loose. )
I have tried tightening the bolts on the bars, and I didn't get anywhere. Of course, I only weigh 160lbs soaking wet.
I can get access to an impact wrench if I need it!
Pepe (My little Mule)
2001 ETH/DEE, 3. 55LSD, Forest Green Quad Cab
Ordered 2/5/01
Arrived 2/28/01
Titled 3/2/01
Don't see how it could be the liner. If you were rubbing against it wouldn't it rub off? I'd double check the brackets. Can you see any signs of contact?
98. 5 3500 SLT Quad Dually 4x4. 3:54 Auto, Waterfall Blk on red. Custom dually flaps, Rhino lining, All acc's w/leather, Muth signal mirrors, Catz MSC's, 55watt back up lights,
BD exhaust brake, Banks EGT/Boost/Temp gauges, Mag-Hytec DC&TP, SS bug screen and fender trim,SS Stull diamond line running boards, SS 4" turn down.
Your nerfs must be mounted too far forward. Do you have mudflaps too? When I get snow/ice/mud packed behind my mudflaps they'll contact the wheels when turning. Ripped 'em off a few times too.
Big MAK
98. 5 ISB 5spd 4x4 Quad Cab 3500, 275s and Original PowerMax
A "WARRANTY FREE" ZONE
https://www.turbodieseltrucks.com
You're not the only one Mark.
I backed up through a snowbank and the rear flaps caught on the tires and they flipped up backwards. It made all kinds of noise.
Y2K Red Stealth Sport 2500 4X4 QC SLT+, 5-spd, 3. 54 anti-spin, 265-75-16 LTX’s (There ain’t no such thing as options, cause ya gotta have it all, including: DC’s dead cow/vinyl interior and don’t stop anti-lock brakes. ) Stock, but not for long. Oops, too late. What silencer ring? (More fun than my 98 SST)
Quick update!
The crunching sound was coming from behind us, hence the wifes feeling it was the bedliner.
I got under the truck and did some tightening of the nerf bars and it helped a great deal.
The truck may have been in a bind when my bars were put on. The bolts didn't move even 1/4 turn, but it sure did help.
Ordered 2/5/01
Arrived 2/28/01
Titled 3/2/01
