CTD Weedeater (Special Thanks)
D-MAX
Extended idle time
Thank you to Lawrence at DD for the special SuperMentalUnhealthy Injectors, To Chris (csutton) for The Margarita Techonolgy to figure out how to start this Dam# thing, and to Greg (cumminzpower) for his unending exhaust pipe work!!!!! Great job, guys!!
Colin
2001 Quad,4x4,AT,4. 10LS,LB,Loaded enough,stock,mostly... . 65 Chevelle sedan, Hella nice driver, 53 Nash Rambler Convt,1 of 653 built,[not a Metro], GM drivetrain, injection, and auto/od
Specialized FSR PRO Stumpjumper,Cannondale F2000, Loaded
MTD Lawn tractor with flames
12' fishin' boat, loaded. .
I love the pull start! Geez, HVAC could save a couple hundred pounds using that on his Red Rocket. No need for a starter, so you wouldn't need batterys, so you wouldn't need the alternater!
ex Ford tech, now driving '01. 5 2500 4X4 QC LB ETH/DEE SLT 3. 54, Patriot Blue
Drawson,
I thought that it needed the turbo hooked to the intake also, then I realized that he is using the optional leaf blower attatchment...
LOL #ad
Caleb
Do you have to rub two sticks together as a grid heater? lol I imagine its overdriven because 3000rpm would just knock the grass down lol. I think the torque is enough to support about a 15000:1 overdrive. Maybe 14999:1 if our using extra heavy sting, Hell I bet you could use chain if you wanted to.
Clark
YEAH BUUUUUUUUUUDDY! That's cool colin... let's ALSO give the fuel pump to Joe Donnelly for further tweaking to make some more smoke. . hell, by the time you get done making smoke the weeds will be dead anyway, won't need to whack them!,,,LMAO!
Greg's 1993 D250 4x2. . 5-speed. . extended cab. . longbed. . bright white. . tinted windows. . 5-inch Peterbilt stack through bed. . "Cummnzpowr Air Intake-system"... . Piers' "tweak inductioned fuel pump"... . PW injectors... 12CM housing... Isspro Pyro &Boost guages. . "Stack-O-Saurus Rex"
