Cummins 101
Filters
What should the cruising RPM be?
I have been debating with a friend of mine about a few things and need some answers.
1. What is the recommended oil change interval for dino oil ?
2. What fuel additives to use, how much and when.
3. Which is better in the Cummins, dino oil, or synthetic. (just the facts please).
4. What the heck does "bombed" mean ?
I know to some this may see like simple questions but it has seemed to stump some of us here. I have been driving Dodge trucks long before it was cool, but I am new to Cummins. #ad
1985 DODGE 1 ton Crew Cab W/8' box converted to 4X4 in 1999. Upgraged to a non-intercooled 1991 Cummins Turbo diesel & rebuilt 5 speed Getrag in 2001. Freshly rebuilt and Balanced Cummins, Rebuilt NP205, Rebuilt Injector pump and tweaked, Matched Injectors, 3" New Mandrel Bent Exhaust,no muffler, Borgeson Steering Shaft, K&N Air Filter, 3:54 gears, limited slip rear end, 16" Goodyear GSA Wranglers, 16K Reese 5th Wheel Hitch,and LE Package, OEM Cruise Control, and a Sony CD Stereo. If you want to know why I did all of this, 3 kids and I can't stand F**d and Ch**y. Kyle Hoover ,Fruitport, MI.
hey man, welcome to the family. your gonna love this stuff of makeing horsepower and not looseing milage or shortening engine life. OK, for myself I use 'rpm delo 15-40 oil'. I change it every 4500 to 5000 miles. I use 'stanidyne' fuel treatment and pump lube. and 'bombed' means pumping up the power and torque till you get a grinn that just will not go away. it's really fun when you can run some of these 'hotrods' into the dirt with a 6000lbs. truck. kinda gives a whole new meaning to the word 'SMOKIN'
late 91, 4x4,pump+25%,pw's,16cm,fresh air,3 1/2 exaust,trans-boost-exaust-oil temp guages, pumped auto,180. 000m,all black
I change oil every 5,000 Km, add stanadyne to the fuel. "BOMB" is an acronym stands for "Better of Modified Baby".
92-LE,4x4,5spd,3. 54,Borgeson steering shaft, Tach,Isspro Pyro & Boost, 16cm2, PW injectors
[This message has been edited by Al Kungel (edited 05-19-2001). ]
Use Stanadyne treatment for the fuel, about 6 oz per fill. Change the oil every 10,000Km, the book calls for 9700 KM. Use Esso XD3 15W40 summer and XD3 0W40 in the winter.
J-eh
Jason Hoffman
93 D250LE CC 5 spd 3. 54 LSD. K&N. Banks Pyro/Boost gauges. E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. Cummins Power Booster member.
185,000 Km (115,625 Mi)
FOR SALE - 89 D250LE 5 Spd 3. 54 LSD Reg Cab. "tweaked pump", BD Injectors, 3. 5" Exst tail section straight.
237,500 miles (380,000 Kms) 7850 Hrs.
89 Pics/March 2001
Change oil every 3k-4k miles. Oil filter too.
Use Delo400 10-40w year around.
Add 8oz (or so) of Power Service fuel additive with every tankful of fuel.
gary
Cummins calls for 6000miles or 10000kms on their maintenance part of their website - they don't specify oil type so we can safely assume that this is with any SG rated DMO (dino oil).
Good luck on the synthetic vs. dino oil topic, I've seen these ones go on and on before.
91. 5 CTD 4X4, 5" Stacks, Tweaked Pump, 33" Boots (in the summer), Unlimited Slip,
Big, Bad Dodge
Originally posted by unclebilly:
... they don't specify oil type so we can safely assume that this is with any SG rated DMO (dino oil).
Nope--remember, the "S" in "SG" stands for Spark ignition. It also needs the "C" rating ( for Compression ignition engines), which according to my '92 owner's manual is CE.
Mike
Hello CrewCabDiesel:
The recommended change interval is 5,000 miles; that's usually what I change mine at, although if I've done all highway driving I've been known to let it go to a little over 6,000 miles. I'm comfortable with that since I use what I feel is the best oil and filter: Cummins Premium Blue 2000 and the Fleetguard Microglass filter. The CPB 2000 is a semi-synthetic. I'll boil down all the stuff I've read/heard on synthetics right here: If you run in extrememly cold climates, or run extremely hard (heavy load constantly), then synthetics are best. They flow better in the very cold and don't breakdown under extreme heat. For most of us, regular oil is fine. My oil stays real clean looking even at 5K, with 102,000 on the engine.
'93 W250 Club Cab, 5 spd, 3. 54, stock engine, 95K miles
I'm using Amsoil 15W-40 HD marine. I've tried 3 or 4 other oils and I noticed one thing almost right away. That was with the other oils, after shutdown, I would hear the turbo spool down for at most 2-3 seconds after getting out of truck. With amsoil I hear it for 6-8 seconds after getting out. I think that is a good sign personally.
The truck does seem to start a bit easier in cold weather (Below 0*C)
I change around every 6000Km depending on driving application.
I'm using stanydine PF for the fuel and notice a cleaner start-up, less smoke with WOT (wide open throttle) and a slightly improved idle speed (25-30rpm more)also smoother idle too.
BOMB > Bosch only my brother, is another acronym i read here.
Regards, Bush'
93. 5 W250 4X4,HD Spring Pkg, Rancho 7000's, Rear Swaybar,Dual Shock Front Stabilizer,BD 180HP Injectors,31/2" Mandrel bent exhaust,BD16cm 'Hot End',Modest Pump Tweaks(lock collar still on)Star Wheel@3oclock/Timed @ 1. 37mm,K&N Air,Isspro Pyro (Post Turbo),Tach,transmission Temp,Auto Meter Oil Filled Boost Ga. , 3:54's, 4 Speed Auto, Clubcab, Aftermarket Reclining Buckets w/ctr Drop Down seat/console, Black over Silver, 22psi,285-65R-16's,American Racing Clear Coat Mags, Amsoil 15W-40HD Marine,12,000 lb. Warn Winch,KC Spots. 103,900 Kms (64,600 mi's). NOT A VENDOR,Just an end user
