Diesel85
It's not something I want to do now, but maybe in two-three years to start playing with my 2000 Dodge Dakota.
I live in Upstate NY, and for those that are familiar with old cars/trucks with NYS, emissions inspections drop (not safety!) at 25 years old. Next year the truck will be 25 years old, so after that I can start tinkering more.
I always dreamed of a diesel Dakota with a stick shift, and coincidentally this truck has everything I would want to have it be (at least to me) interesting with a diesel engine in it.
Right now it's spec'd as follows:
Regular Cab
3.92 Limited Slip Rear axle
2 Wheel Drive
6 Lug Axles
HD Front and Rear Suspension
4.7l Magnum V8
NV3500HD Manual Transmission
Air Conditioning
No cruise or anything fancy.
I want to convert it to diesel -- but conservatively. Not drop a 6BT or something gigantic in the frame. After doing probably many years of research (little by little), the holdup has always been at that NV3500 transmission.
So I was bored last night and I decided to see if anything new has come up, but I must've typed the right "Google Magic" words in and I found that Cummins states the NV3500 will bolt right up to the 2.8l and I can provision some A/C for it. Also includes a vacuum pump for the brakes, so I don't need to mess with a hydroboost setup.
https://www.cummins.com/engines/repower
Mind you, this is NOT a daily driver truck. Sits in my garage as a garage queen. No rust and I just keep up on it. My family is the original owner of the truck. I want to essentially make it into something "interesting" to bring to car/truck shows as I get older... you know, park it on the grass, open the hood, and let people marvel at it, while I sit in a $10 lawn chair sipping some crappy iced tea... (that's my idea of fun!)
Best of all, they are priced reasonable at $10k for a complete engine, ECU, throttle pedal, and other goodies.
When I do take on this project, I want to buy the engine, redo the cooling package, a freshly rebuilt transmission, redo all four corners, bushings, driveshaft (possibly do aluminum), and rear end job. Possibly a new paint job.
Rough estimate to do what I want to do looks like $25k.
I guess my nagging question is... am I out of my mind to do this? Or do I just leave it alone and leave it stock forever?
Regular Cab
2 Wheel Drive
6 Lug Axles
4.7l Magnum V8
Air Conditioning
