Engine/Transmission (1998.5 - 2002) Cummins 24V airplane engine????
2nd Gen Non-Engine/Transmission need help with trim rings
Engine/Transmission (1998.5 - 2002) edge comp 200 bills??
Just came across this in the latest edition of AVWEB's weekly newsletter. Too Cool!!!
"A NEW GA POWERPLANT FROM AN OLD, WELL-KNOWN MANUFACTURER
Noting that the current development of general aviation diesel
powerplants relies on unproven designs that have yet to overcome
inherent problems with excess weight, Cummins Diesel spokesperson Phool
Ng Yu yesterday told AVweb that the company plans to enter the market
with a variant of its venerable 24-valve turbo diesel used in Chrysler's
Dodge Ram pick-up truck line. In its aviation version, the Cummins
diesel will pound out 245 HP at 2,700 RPM and a propeller blade-snapping
505 foot-pounds of torque at power settings as low as 1,600 RPM. Yu
told AVweb that the company is projecting that its combined STC package
will not require a reduction in useful load in most installations. "
Greg
Hmmmmm... ... ... April Fools, right?
98. 5 24V QC 4X4 AUTO, 275'S VA, PE, DTT TC AND VB, PSYCHOTTY AIR, BOOST AND PYRO GUAGES, AEROQUIP
FUEL LINES BY V. M. , ESPAR HEATER, 2" SUSP. LEVEL, 255/855 DUNLOPS, AMSOIL FLUIDS.
Would probably work with a 12 valve, less weight you know, hehe
96 SLT Laramie CC 5spd, 3. 54, no muff, no cat, 5"turn down tip. (its for sale)
. Member NRA/USPSA
We put a three cylinder diesel in an Unmanned Aerial Vehicle back in 95. The Navy didn't want gasoline on carriers so we switched to a "heavy fuel" version. Don't know who made the final version. It might have been Perkins.
YOU BA$TARDS!!!
I was reading the post, getting all excited that my two favoritest things in the world were being combined, the Cummins and the airplane... then I look at the dates on the posts! Grrrrrrr... ... .
Depending on who I end up working for, it is my plan to build a reliable Cummins diesel powered aircraft. I just hope Cummins still wants to work with me on a project like this. :)
Originally posted by jwilliams3
just hope you dont have a lift pump go out at 10,000 feet.
Talk about fast wrenchin'
Would you need it with a high wing airplane? Maybe a redundant gravity feed... . ;)
Josh doesn't design/build high-wing airplanes. :) LOL
I'm looking at fast and sleek with huge useful load... . too bad the way torque works with pickups being able to carry bigger loads doesn't translate to airplanes... .
They better go back to the inline injection pump, like jw3 said, I'd hate to be at 10000 ft and have to make use of a parachute and junk a other wise perfectly good cummins! Just because of a lift pump or failed 44.
Anybody notice the dudes name?
"Cummins Diesel spokesperson Phool Ng Yu"
Pronounced Fool-ing-you! Haha! Dirty trick guys.
GregNH was trying to pull a fast one. .
Post date on the first post is April 02 2001.
Packard made radial diesel aircraft engines in the '30s as well as Guiberson (sp?) I think what happend to aircraft diesels it that people who fly airplanes aren't worried about the cost of fuel. Same reason most people choose gas V8 and have for a long time.
