I finally installed my '00 Dodge/Cummins (black) valve cover. It looks absolutely awesome! Especially since I have a Black Sport.
MichaelT: I like the Dodge/Cummins valve cover because the top of the valve cover has an angle running the length of the cover, the Cummins cover does not. The Cummins cover appears a little "blocky" and bland to me. Just my opinion.
The expression: "they don't build 'em like they used to" holds true to the 24v, valve covers as well. My '98. 5 OE valve cover weighs 7 5/8 lbs. (inc. oil fill cap. . no hold down bolts), my new '00 valve cover weighs 4 1/4 lbs (also inc. oil fill cap. . no hold down bolts). That's a disparity of 3 3/8 lbs. (all weights were taken with a Chatillon 0-15 lb. scale). I must have gotten a hold of the "racing" version. LOL The raised center rib running the length of the top of both valve covers is relieved on the underside of the '00 valve cover only. I also suspect the '00 valve cover has a thinner wall thickness however, I did not bother to mic. either cover. At first I was concerned about the possible increase in valve train noise although, after firing up the big beast, I wasn't able to detect any perceivable increase.
A G-R-E-A-T B-I-G THANK YOU to MikeR for his continued effort in obtaining this *****in' valve cover.
'98. 5 2500 QC 4x4, (BLACK) SLT Sport, ISB, LWB, 3. 54 LSD, A/T, Glasstite Vision II canopy, Line-X bed liner, 285/75R16 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, Mopar tow hooks, Jordan Research Ultima 2020 trailer brake controller, VDO Vision gauges, PIAA Dual Sport 900 auxiliary lights and Super White bulbs, BD exhaust brake and TorqLoc, Prime-Loc fuel filter relocation kit, Bosch 275 hp. injectors, VA CPC, DD Boost Module, Banks Stinger wastegate actuator, "Scotty Air System", BLACK '00 valve cover, Hitco/Geno's exhaust blanket, Femco/Geno's EZ Drain oil pan plug, Banks Stinger 4" dia. stainless steel exhaust system, plus many other trick modifications
'00 Polaris 6x6
