Big looks no one wanted in the great oil debate. I got to using John Deere oil about 10 years ago because a 55 gal drum of their 50 plus oil just showed up in my shop for the most part. After having the valve cover off of one engine that had over 100k miles of this oil run through it and how clean it was I was sold. It is designed for extended us and for equipment that sits around and then is run hard when it is used. In my opinion just what you are after. They have a couple of viscosity of it too so pick your best option.
Yeah it is high but with some of the discounts I get and buying by the 55 gallon drum it is $10-11 a gallon for me.Looked at it at the JD Dealer in town $340.00 for an oil change is a bit steep for me without filters![]()
My reccomendation?
If it’s under 125 hours a year, just one annual major PM with best filters and basic 15/40 Dino will suffice. I might add a oil pan warmer for those -20* spurts.
that sounds better than the $26.00 a gal I was quotedYeah it is high but with some of the discounts I get and buying by the 55 gallon drum it is $10-11 a gallon for me.
