Cummins B in 73-79 Ford anybody?
Engine Swap into 80 model
cummins conversion problem
Hope I don't get run out of town on a rail for asking this as my first post but here goes:
Several years ago I put a 6. 9 Navistar in a 75 F250 4X4. After learning about cavitation erosion the expensive way, it was put back on gas and all was sold.
I have been toying with the thought of trying to stick a Cummins B in a 78 or 79 F250/F350 4X4. Has anyone out there tried this including aftercooler?
Scot
Scot, I have seen the CUMMINS B5. 9 in a 1986 Chev and in a Ford it took some work they said if a person was to do the swap, that the person should get all the parts out of the same pick-up. You may want to talk to c-series-man ,he put a CUMMINS C8. 3 in a1995 Ford. He may have an idea for you. I know he hangs out in the 2nd gen. form he sounds like he know a thing or two about the job.
95 Ram 2500 slight ENHANCEMENTS!!
yea he had pics of the install as well. Nice looking ride. Only other one was a guy in Fla who had a conversion of a F-350 running with the Orig ZF 5 speed it was a shop that did the swap tho. Mike
http://hometown. aol.com/hotshothauler/myhomepage/business.html 2000, Air brakes on truck & trailer. 179,000 miles todate. DOT custom built sleeper unit. pulling a 40' G/N flatbed
2000 FL-70 Pulling a 48' low boy.
I have two older brothers both of them have put a six cylinder Isuzu in 79 Fords. They had a length problem and ended up not useing the engin fan but two electrics instead. other that that.
93 W350 5spd White 3. 54 gears 4" stack Powerwagon Injectors. Headache rack with lights. Cummins Mudflaps. 2" lift on seat. Goosneck ball Beefed up reciever. Fog lamps, Back up lights. CB 98 Factory sound system
A B5. 9TA fits nicely in a 84 F-250. Compare the dimentions of a 84 with a 73-78, that should give you a good idea if it will fit.
CPFF
CUMMINS POWERED FAST FORD
