I do have some serious voltage running the house SORT OF this Indiana home is total electric, or I should say IT USE TO BE!!
Im not really into working on electric after getting knocked on my XXX with 220 one time, it was enough for me to let someone with EXPERIENCE & KNOWLEDGE do all the work. I will have a Miller wire feed in the shop extra large compressor.
The reason I say sort of is that I installed a Heat Master Wood boiler for heat but kept the original Elect. system as back up. I was thinking about the Elect. water heater being used part time by running the house hot water run through the outside boiler but have decided to see what the boiler can handle before I make the determination, Im going to have a shop built in the Spring and hope to heat it with the boiler.
I have someone that knows what he's doing from where I work going to make ALL the connections he's the Electrician that fixes the problems at the fuel Rack of the company we work for, I'm sure that doing this will pose no problem for his skills.
The main reason for going with something this large is that it will handle the ENTIRE house with no problem & the fact that I can do everything to the Cum-A-Part Motor. Propane is outrageously priced here in at least this part of Indiana & the lack of NG located on the property helped with the decision also.
FREE DIESEL HELPS A LOT TOO
