Cummins Big Cam III
clutch hydraulic line
96 GMC conversion
I was at Inland Kenworth this morning trying to buy some filters for my '95 and they had a sheet of paper taped to their counter:
Recon Engines!!!
Cummins Big Cam III, 400 h. p.
Out the Door: $9,975. 00
1 Yr. 100,000 mile warranty
Core Charge $8,975. 00
That Big Cam is early 1980's technology isn't it? I wonder if some friendly nut has ever put one in his pickup?
The parts guy also told me Inland Kenworth used to sell adaptor kits to put a Cummins B engine in Ford and Chevy Pickups. He said the kit had "everything you needed. "
4bt kit in 84 chevy dually
I used the kit to install a 4bt in an 84 chevy dually. It worked out great as the truck has passed 200,000 and the only failure was the alternator bracket. I changed the 4. 10 rear to a 3. 73. I could still use another gear. As to a Cummins 350 in a pickup you realize that the engine weighs about 2500 lbs plus 700 for the trans. The engine governs at 2200 rpm so a serious od is required. But fear not as soon as I put a 5. 9 in my 54 White 3000 COE I have worked out a lot of these problems for my next project.
It would fit in the bed :eek: and you could try to get the transmission in an extended cab inside the cab :D with a drop box right next to the driver :eek: to get the power down to the driveline, a rear end out of a semi :eek: would complete it. Put a 5th wheel plate on the #1 valve cover and you would be THERE man!!!:D :D
