Cummins Dakota
Fuel Mileage 2002 HO?
1975 Ford F-600 conversion
Anybody see the new Street Trucks mag with the article about Banks putting a 24 Valve in a Dakota to try and set a land speed record? They're going to use the truck to tow their equipment out to the lake bed then change the tires and gearing, try to do a couple high 100mph or even 200mph (I gotta see this), then tow everything back home. They had a pic of the engine bay with the Dak all chopped up. Pretty cool to see.
If you goto the Banks website you can read all about it in depth. Its worth reading.
GOALS
To establish Cummins compression ignition technology as powerful, clean, quiet, efficient and desirable – something the consumer wants in a light-duty truck or sports utility vehicle.
To position the brands of Cummins Engine Company, Holset Turbo and New Venture Gear as the technology leaders in this arena.
To use this advanced technology to establish new speed records in excess of 210 MPH using a compression ignition, turbocharged engine powering a Dakota pickup that is STREET-DRIVEN, TRACTABLE AND FUN.
PROJECT SIDEWINDER
Banks Race Shop prepared Dodge Dakota Pickup with all creature comforts for highway driving
Cummins 2003 inline six cylinder compression ignition engine with common rail injection
Holset variable geometry turbocharger
New Venture six speed gearbox
Wilwood braking system
Progress Group coilover spring/shock units
Banks engine modifications and turbo system
600 brake horsepower
1000 pounds-feet of torque
210 mile per hour record speed at Bonneville
Establish 1/4 mile drag racing record for diesel
20 miles per gallon fuel economy
Quiet running, low emissions
100% highway drivability
Tow race equipment in trailer to Bonneville, drag races, et<hr>
Truck Bio:
Y2K+1 3500 4X4 Quad Cab 4:10:1 LSD
Somewhat Powerpacked By Bank's (4 inch exhaust,High ram intake,~Minus~wastgate mod to 38 psi,~Minus~ottomind TLC +guages,K&N) ,Blue Chip Premium FMC DTT~93%TC~&~VB~TC Smart controller, Mag-Hytec's Double Deep Trans pan,DD III injectors+Van Aken+Autometer Guages. ,Piers Modified PDR HX turbo,Enterprise Engine PerformancePusher pump setup Front End Leveling Kit from Jakit with 255/85R16 BFG http://www.bfgoodrichtires.com/ M/T's Custom Rhino Liner (see Tool Man's truck feature)DeeZee Black Diamond Plate Bed Rails And Tool Box , WAAG Side tubes with kick~outs Mopar Performance accessories-Sill plates-hitch cover-cargo aux lamp'n'Power, Hadley air systems 150 psi comp and air storage. DynaMat Sound deadening applied to entire cab and doors, Check out Tool's Stuff~>Here!<~
N. E. T. D. P
Three worded story ... ..... "over 1350 response posts - a new record!"
20 mpg? Jeff's 12 valve Dakota gets on the order of 30+ mpg.
I want to see them get the drag racing record while rowing through the 6-speed. At Muncie, we were really hoping they would be there. It would have been cool to have the two dakotas race each other. Maybe next year.
Josiah
