Cummins engine brake switch
New truck! funny trade in story
Sirius
Does anybody know the part number or can recommend a place to purchase just the 6-Speed lever mounted switch?
I'm installing air horns, and think that a lever mounted switch would be the way to go, as my hand is usually on the lever any how.
Does anyone else make a lever mounted switch?
Iv'e got them. $30. 00 delievered.
There's an add in the classifieds, if you want to check it out.
Stick
Try varad.com
and click onto racerboy shifter knobs (activates relays) to operate anything your heart desires. Have one on mine and works and looks great. Also has 4 programmeable buttons for latching or momentary.
Dan
for air horns you probably want a momentary one
varad had some.
I have known for several months the type of switch I wanted to operate the ebrake (turn off @ lights/low rpm)
2spd axle switch, shifter mounted
if you want a kit Cummins has them 04'- $95 #5102082AA
some others offer kits
most supply house's are gone and kids with computers think they turn on the headlights.
Including the commercial dealers.
After seeing samples under 15 brand names all were the IDENTICAL knockoff from china different boxes
priced $3. 89~18. 99
Today in my hand is the U. S. A. version(the one they copied)
several mm larger and few oz. heavier. $9. 00
Still fighting for the discontinued bracket 11. 00 harness 18. 00.
also the blue knobs $12. 00
If you can use a red switch alone they have more.
