By the way he also told me that D/C owns allison!
LOL!!
Here's the info straight out of the press release from the intro (that I put on here back in February -
https://www.turbodieselregister.com/hdlaunch/04_Specifications.pdf ):
<table><tr><td>SPECIFICATIONS</td></tr>
<tr><td><b>TRANSMISSION: </td><td> 545RFE – AUTOMATIC FIVE-SPEED</b></td></tr>
<tr><td>Availability:</td><td>Optional with 5. 7-liter engines</td></tr>
<tr><td>Description:</td><td>Three planetary gear sets, one overrunning clutch, full electronic control, electronically controlled converter clutch</td></tr>
<tr><td>Gear Ratios:</td><td></td></tr>
<tr><td>1st:</td><td> 3. 00</td></tr>
<tr><td>2nd:</td><td> 1. 67 – upshift; 1. 50 kick-down</td></tr>
<tr><td>3rd: </td><td> 1. 00</td></tr>
<tr><td>4th: </td><td> 0. 75</td></tr>
<tr><td>5th: </td><td> 0. 67</td></tr>
<tr><td>Overall Top Gear:</td><td> 2. 50 with 3. 73 axle and 2. 63 with 4. 10 axle</td></tr>
<tr></tr>
<tr><td>TRANSMISSION: </td><td><b>47RE/48RE – AUTOMATIC, FOUR-SPEED OVERDRIVE</b></td><tr>
<tr><td>Availability: </td><td> 47RE – Optional with 8. 0-liter V-10 and standard-output Cummins diesel engine</td></tr>
<tr><td></td><td> 48RE – Optional with 8. 0-liter V-10 and standard-output Cummins diesel engine</td></tr>
<tr><td>Description: </td><td> Hydraulic control, electronically controlled governor overdrive, overdrive lockout and converter clutch</td></tr>
<tr></tr>
<tr><td>1st: </td><td> 2. 45</td></tr>
<tr><td>2nd: </td><td> 1. 45</td></tr>
<tr><td>4th: </td><td> 0. 69</td></tr>
<tr><td>Overall Top Gear Ratio: </td><td> 2. 57 with 3. 73 axle ratio and 2. 82 with 4. 10 axle ratio</td></tr>
</table>
As you can see the new 5 speed transmission is an option for the Hemi only. The info that we got at that time was that the 48re would also be available with the HO when it's released. BTW, they also told our group at the nationals that the 48re would be exhaust brake compatible.
