Cummins implant into Hummer
47rh
Fuel Economy- A Funny Thing Happened
I just got a call from a custom shop that in doing a conversion on a Hummer. He said that he is installing a 2001 Cummins in this Hummer and he is looking for a stand alone wiring harness...
Any ideas where he can find one???
Thanks
Rick
You don't need a stand alone harness. The cummins harness on the motor will do with little modification. If the engine was out of an auto the ecm may have to be changed over to a 5 speed ecm. Just get ahold of a wiring diagram and trace the wires.
Malcolm
Does anyone have a stock wiring diagram for the engine? Also I plan to use an auto anyways so using the "auto" ecm should be what I ant I think.
Call Kenny at Autoworld in Great Falls, Montana. He has dealt with numerous 24 valve engines and has the wiring issue down. There is not much you need to have to make them run. It is a lot less headache than you think.
Kenny's # 406 727 8915
Dawna (Kenny's wife and partner) is frequently on this forum. Check for the username Autoworld in this section of the forum.
