Template errors
  • Template public:thread_view: [E_USER_WARNING] Method canConvertThreadToRmsItem is not callable on the given object (SV\SearchImprovements\XF\Entity\ThreadCollab) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsReview is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsQuestion is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsFaq is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsEvent is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsLocation is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsCheckIn is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
Cummins newsletter
Injector washers - explain to me....
8.3 ISC CAPS Injection Pump....
I just got a (email) newsletter from Cummins. Never got one before:confused: Anyway, here are two questions of interest in the faqs section. I wonder WHO determines if the damage was caused by an enhancing device?
Maybe you guys have seen this before, but its the first I received.
Will I void my warranty if I use any aftermarket performance-enhancing devices?
If you use any aftermarket performance-enhancing device and it is determined that the device caused damage to the engine, drivetrain or vehicle then, yes, your warranty would be voided for that damage.
Does DaimlerChrysler authorize the use of high-flow aftermarket air filters such as K&N with my Cummins engine?
No. DaimlerChrysler and Cummins do not recommend the use of increased-flow air filters such as K&N because they can allow contaminants into the intake that can ruin an engine (scoring the sides of the pistons, etc. ).
That doesn't sound like anything new? I have allways gone with the notion that "I am my own warranty station". I think most reasonable foks, know that anything they do to there Cummins or Dodge trucks can and will affect there warranty.
yknot,
I agree with you completely, I break it, I fix it. I was curious, does Cummins determine it or does the dealer? The questions weren't mine, they were in the faqs section. I haven't been around these trucks as long as you have, so I am just curious.
Robin
Dodge provides the warranty...
so they say what voids it. If your warranty is voided, the vehicle gets flagged in the DC computer. Cummins sells the engines to DC without warranty. :rolleyes:
