Cummins or Dodge part numbers needed for Holset turbo
injector qeustion
No codes loss of power
I am having a hard time finding the Cummins or Dodge part numbers for the O rings that seal the oil feed flex line to the turbo and at the other end to the oil filter adapter. The O rings go onto the steel fittings that the oil line screws on to. I also need the part number for the O ring that is on the steel fitting that screws into the turbo main body. That O ring seals the fitting to the turbo main body. I am going to call Cummins Pacific if I can get the part numbers. Thanks.
This what you're looking for?
Good Job Scott.
So there is no confusion you will need (4) o-rings to reseal both ends of the turbo line and fittings. You may as well change all 4 while you're there.
(2) of the 3922794
(2) of the 3678603
Scott,
What I do for clarity when posting these diagrams and illustrations from Quickserve is to pick the large setting for the illustration and then save it as a "png"........then I take the parts list itself and blow it up a bit before doing the screen shot. It makes things a little easier to see. Have to upload two items that way but the parts list is far easier to read.
I believe you can sign up for one ESN free of charge. That used to be the case, then they charged for a subscription, and now I think the one free ESN is back in play.
