Cummins Part # for '99 Lift Pump?
2WD Versus 4WD 3500's
Routine Maintenance Schedule
Does anyone have the Cummins part # for a new lift pump on my '99? I'm not looking for the motorhome lift pump, just the "drop-in" replacement for the P. O. S. stock lift pump. I did a search using "lift pump" and came up with a ton of posts, and didn't see a part #.
Does anything else need to be replaced when you replace the lift pump?
Thanks!
Steve
The Cummins part #3938435. I re-used the compression washers on mine without a problem. They can be replaced if you want, no other parts are necessary. It's easier to do if you detach the fuel filter bracket first, then you can do the whole job from the top. Have fun!
