this is the reply I got from Cummins after asking about the lift pump problems.
here goes;
Summary: lift pump failures
Solution:
Thanks for your E-mail message. We apologize for our delay in responding.
Cummins newest “Midrange” engines (5. 9L and 8. 3L) are electronically controlled and use electric fuel “lift” or “transfer” pumps. The pumps are used in conjunction with Bosch fuel injection pumps to pump fuel from the fuel tank to the fuel filter. Cummins has developed a new high-pressure CAPS fuel system that will eventually be used on all Cummins Midrange product line.
The ‘lift’ pumps are powered by 12V or 24V DC (depending on the electrical system of the truck) and are controlled by the Engine Control Module (ECM). The pumps are centrifugal vane-style pumps, with free-floating vanes that ride in a circular rotor that is offset from the center of the pump chamber. The rotor is turned from below by the motor, and fuel is forced through the pump because of the volume change as the rotor turns and the vanes slide into and out of the rotor, following the walls of the pump chamber.
The electric transfer (lift) pumps have a pressure relief valve that keeps the pressure at roughly 10-12 psi. The ECM can duty-cycle the pump (i. e. , turn power on and off very quickly) to let it produce a fraction of the regulated pressure (i. e. , 5-6 psi during engine cranking).
Earlier mechanically-controlled engines used positive-displacement lift pumps mounted to the side of the block. The lift pump’s plunger follows a dedicated lobe on the camshaft, alternately filling and emptying the pump. The check valve on the inlet closes when the plunger is compressed, forcing fuel through the outlet check valve. The outlet check valve closes when the plunger extends (pushed by an internal spring), allowing fuel to be pulled into the pump chamber. These pumps are not equipped with a pressure relief valve (or regulator), so one had to be installed elsewhere in the fuel system.
These lift pumps are purchased from an outside supplier and they are continually working to improve the quality of their product. There have been several part number changes over the years that represented improvements to the pumps. The supplier receives warranty information from Cummins on pump failures so they can take the appropriate action to make improvements and modifications where necessary.
Thank you for your interest in Cummins power or products. Please let us know if you need assistance in locating the nearest Cummins-authorized distributor or dealer. Please feel free to use our International Dealer Locator: (http://www.cummins.com/partserv/intro.html) found on the Customer Assistance page of the Cummins website (www.cummins.com).
Let us know if have other questions, or if away from your computer, feel free to call us (toll-free, from North America) at 1-800-DIESELS (343-7357), or 1-812-377-5000 (toll call, worldwide, ask for 800-DIESELS).
Regards,
maybe we should all burn down the phone lines with questions, and see if they can "improve the quality" a little faster.
I also asked about recalls or upgrades once a fix is derrived at. they seemed to miss that point though.
this CAPS system they spoke of anyone heard of it?
here goes;
Solution:
Regards,
