Engine/Transmission (1998.5 - 2002) Cummins reply to lift pump inquiry
Engine/Transmission (1994 - 1998) Power to Shut Down Solenoid Problem
Engine/Transmission (1998.5 - 2002) #$%& Lift Pump
I thought this was a good reply from Cummins to my question. Summary: ram isb lift pump concerns
Solution:
Thanks for your email Steve. You will have to speak with Dodge about
their plans to address lift pump issues in their vehicles; we have
different configurations, fuel system interfaces and filtration for various
applications of the ISB - including no lift pump at all. The latter
case is where there is sufficient "head pressure" and low restriction of
fuel flow to the VP-44 Bosch pump.
Also, the lift pump supplier, Federal Mogul, has been through a few
iterations of pump design; you might to well to procure one of the latest
configuration pumps as a back up. If you feel strongly that the pump
is an inpending or incipient failure mode it would be a good idea to
have one; at a minimum you'll be able to assist other Dodge ISB owners on
the roadside - we don't feel that this is necessary. The latest ISB
lift pump which supercedes previous and has all of the latest rev's and
seems to be working well in the field is P/N: 3990105.
One concern in general, and in particular with respect to remote areas,
is fuel quality. If you have reason to suspect marginal fuel quality
(a cause for many lift pump failures) and routinely drive in areas where
this is possible, you might work with the local Cummins Distributor to
add supplemental filtration to your unit. In other markets for the
ISB, primary filters are used in conjunction with the secondary one used
on your Ram truck. We do not specify this as an Application Engineering
Bulleting requirement for the ISB in Ram applications; then again, we
do specify, clean, contaminant and moisture-free premium #2 diesel fuel
... . we do recognize that fuel of adequate quality is not always
available.
The lift pump issue is important, because a failed or failing lift pump
can cause contamination to reach the VP-44 or can cause negative
pressures at the inlet to the VP-44 high-pressure electronic Bosch injection
pump; such can damage the pump through several different failure
mechanisms. The VP-44 is lubricated by the fuel, and sufficient fuel of high
quality is necessary to protect it. There were initial problems with
both the lift pumps and the VP-44; both have been upgraded and many
upgrades, changes and improvements were incorporated by the time your
engine was built.
Some customers have also installed pressure gauges on the outlet of the
lift pump and ahead of the injection pump, to verify positive pressure
to the VP-44; this is all well and good, but does present another
failure mode and additional fuel leak path opportunity, and we do not feel
that such monitoring gauges are necessary. Clean, contaiminant and
moisture-free fuels are necessary, and this should be your main concern.
Here is some more information on the VP-44: The VP44 is a
radial-piston pump with 3 pistons. The pistons are attached to the distributor
rotor and the fuel pump shaft. The pistons ride inside a cam ring (think of
a donut with a "bumpy" hole) so as the pump shaft rotates the piston
carrier, the pistons are compressed towards the center, pressurizing the
fuel. The pressurized fuel is then directed to the proper cylinder by
the distributor rotor.
The cam ring can be rotated in a "retarded" or "advanced" direction;
this is done using a solenoid valve, which modulates pressure to a
fuel-pressurized piston beneath the cam ring. Also, the start and end of
injection are controlled by a solenoid valve.
Although the VP44 was initially not as reliable as we would have liked,
Cummins and BOSCH are confident in its reliability today. The VP44 is
much less complicated internally than the P7100, and it has many fewer
finely machined parts. We don't know for sure that BOSCH considered
low-sulfur fuel when designing the pump, since the pump is fuel lubricated
and today's fuels are low-sulfur.
The VP44 is completely fuel lubricated, as the VE pump is. It does not
use oil lubrication like the P7100 does. The VP44 is expected to last
at least a long as the P7100 in normal automotive applications. However,
we obviously have much more "long-term" experience with the P7100 than
we do with the VP44, so our knowledge base is still evolving. Soon
after launch, the VP44 had its share of problems, just as the P7100 did
when it was introduced, but we have worked closely with BOSCH to correct
the issues with the pump, and we're confident that the VP44 will be a
reliable fuel pump.
Fuels with low lubricity can cause increased wear or seizure of the
VP44 fuel pump internal components. If you are not sure of the fuel you
use add a lubricity additive is required.
In March 2000, we contacted Bosch and they advised us that the
so-called "B-10" life of the VP44 is 2000 hours at full fuel rating. In other
words, If a pump were operated at 100 percent rated horsepower for 2000
hours, only 10 percent would fail; 90 percent would be okay. As the
typical duty cycle of the Dodge Ram is considerably less than this, the
expected life expectancy is considered more than adequate to meet the
needs of the Dodge Owner
The electronic controls on the 24-valve engine allow Cummins to control
the power and torque very precisely across the entire RPM range. The
mechanically controlled engines have their power and torque precisely
controlled at torque peak and rated power RPMs, but between those two
engine speeds, power and torque can often exceed the published figures.
Do be sure you use quality filters and fluids. We have found their
greater initial investment to be a good idea and to actually lower the
total cost of operation per mile, or hour. Cheap filters are a poor
investment.
Enjoy your truck and drive it anywhere you want to go. It should do you
a good job. Take the other actions as appropriate given you fuel
quality and sensitivity about "mission disabling failures. "
Thank you for choosing Cummins power or products. Please let us know if
you need assistance in locating the nearest Cummins-authorized
distributor or dealer. Please feel free to use our International Dealer
Locator: (http://www.cummins.com/partserv/intro.html) found on the Customer
Assistance page of the Cummins website (www.cummins.com).
Let us know if have other questions, or if away from your computer,
feel free to call us (toll-free, from North America) at 1-800-DIESELS
(343-7357), or 1-812-377-5000 (toll call, worldwide, ask for 800-DIESELS).
Regards,
Powermaster
Customer Assistance Center
Cummins, Inc.
Columbus, Indiana, USA
Email: -- email address removed --
"... pressure gauges... . do present another failure mode, additional fuel leak path opportunity, and we do not feel that such monitoring gauges are necessary. Clean, contaiminant and moisture-free fuels are necessary, and this should be your main concern. "
Does this make any of you with a fuel pressure gauge wonder, like it did me? Every once in a while I can smell fuel in the engine compartment. I think it is coming from the fuel gauge connection.
Steve
This statement:
"The lift pump issue is important, because a failed or failing lift pump can cause contamination to reach the VP-44 or can cause negative pressures at the inlet to the VP-44 high-pressure electronic Bosch injection pump; such can damage the pump through several different failure mechanisms. "
is followed by this statement:
"we do not feel that such monitoring gauges are necessary. "
:rolleyes: :rolleyes: :rolleyes:
I'm keeping my gauges.
No.
If installed correctly, this is not an issue. My fuel pressure gauge has already saved me once from a marginal pump that would have otherwise been undetectable until it was too late.
That is about the most intelligent answer I've ever seen from an OEM. I've gotten a few good returns from the Powermaster... but never anything like that. At least we all know Cummins is aware of whats going on in our world.
They summed up exactly how I feel. A good fuel filter/water seperator before and after the lift pump is not going to hurt anything. Thats exactly what I did. But I think I'll keep the gauge as I dont agree its a problem "causer".
Some of that has been posted before but some looks new. I like the part about some applications using no lift pump at all. Must be nice to have that kind of tank elevation.
Fuels with low lubricity can cause increased wear or seizure of the VP44 fuel pump internal components. If you are not sure of the fuel you use add a lubricity additive is required.
The only thing that's out of our control is the quality of fuel. We just never know for sure what the quality of fuel we are really getting. Any suggestions on an additive?
Reference Book
Excellent reply!!! I know the internals of the VP 44 have been a mystery, and I'd like to offer a suggestion that I found very useful.
The Society of Automotive Engineers (SAE) publishes a book written by Bosch on diesel fuel injection. It includes detailed operation, pictures and diagrams of the various pumps Bosch makes. One section covers in-line pumps (P7100) and another covers radial pumps (VP 44... although they call it a VR-series in the book, I'm sure there are small differences but I can't tell).
It's technical enough to explain it well, but not in rocket-science lingo.
www.sae.org (search: Bosch Book)
Re: Reference Book
Using the industry accepted standard that one hour equals 50 miles 2000 hrs = 100k
I know this is at 100% rated power and only 10% will fail but this sort of nixes any hope of a ISB reaching 500k.
My lift pump last about 45 k. I'm at 135k on the ticker and it's time for my 3rd lift pump. Pressure has dropped from 20 to 15 psi when cruising at 70 in 6th. At WOT, box on 5, psi drops to 6. Used to stay at 12. This is with the use of a helper pump. See sig... I can change out my lift pump blind folded with one hand tied behind my back. Not sure that's something to brag about.
No lift pump
"THAT" was interseting. If you could eliminate the damn thing you would never have a failure.
So... . I'm wondering what is the normal pressure build-up in the fuel tank while the engine is running. There's all that return fuel constently being sent back the the tank. Would it be possible to add some type of air pressure releif valve to the tank/vent system to raise the fuel tank pressure to say... . 6 to 10 psi. That would keep the VP 44 happy and you could just toss the lift pump.
I also wonder about the crankcase vent tube. We're all trying to relocate that thing. Maybe it could be plumbed into the tank to create positive pressure (and get rid of the oil fumes) along with a relief valve and bingo... no more lift pump.
Any thoughts on this ... or am I just losing it?
Mike
I guess I was thinking the total gpm would be the same but the pressure would be greater on the return line side. But after readine your post I think you're right. It's all going to equal out in the end.
Mike
Mike, think they're talking about a tank that is higher than the engine for no lift pump.
The fuel cap and the vent on top of the tank are set to release pressure at about 2 psi. I would be concerned about the tank splitting open if you tried to pressurize it more than 10 psi especially when the fuel is 140° after a long cruise.
Also your blowby shouldn't be putting out more than 5 psi unless you have a valve or ring problem.
Nice try though. :cool:
There'e still hope
Bill, Ok... 5psi with the crank case vent..... a relief valve on the tank set at say... 6psi, to protect the tank... and 1/2 in fuel line all the way to the injector pump.
That still sounds more reliable than the stock system.
God. . are ate up with this stuff or what???
I really did contemplate T'ing my extended crankcase vent line into the tank vent right there below the filler cap. I wasn't sure if the back-pressure would screw up the engine venting or not. Where did you get the 5psi for crankcase ventilation by the way?
I still feel that there is plenty of "free" pressure somewhere on the engine. Bosch claims the VP44 simply needs positive pressure for operation. This should be simple... No! The fuel filter might be the real problem however. Whatever is gained using the tank for an accumulator might get lost passing it through the filter.
Hell... I don't know... but it's kinda fun to think about it.
Mike
Re: There'e still hope
I still feel that there is plenty of "free" pressure somewhere on the engine. Mike
It is my understanding that if you pressurize the crankcase by restricting the crankcase vent, You would be jeopardizing oil seals.
jjohn you are exactly correct ... i was playing in the mud with my '91 and stuffed the vent tube full of mud ... all my accomplices started yelling and waving their arms, i stopped and to my horror there was motor oil everywhere ...
it had blown the dipstick out and the inspection cover gasket off the drivers side of the block ... one of the hardest gaskets i've ever replaced ... had to take off the injection lines etc :{
Isb blowby specs: 10" of H2O using a . 302 orifice and water manometer.
27" of H2O = 1PSI
5PSI = 135" of H2O
At 5psi crankcase pressure you will blow every seal out of your engine.
Be careful about restricting the blowby tube.
A Johnson
I am not entirely sure that I would want crankcase vapors introduced into the fuel system. Some of the vapors are water. Another component would be sulphuric acid that is formed during the combustion process, and not nuetralized in the oil. The water
could be filtered, however I don't think that the acids would do the fuel system any good over a long period of time.
Many of the points already made are well taken. The ability of the tank to withstand increased pressure along with the effect that it would have on the engine's seals is critical. In the event of a system malfunction or unforseen operation parameter, cross contamination of either the fuel system or engine lubricating sytem must also be considered.
As has been stated, this is interesting discussion. I believe that it is possible to find solutions to problems in this manner as there is an wealth of knowledge here and all it may take to arrive at a solution is for someone to ask the right question.
The Fass System is interestion, and expensive. Bed mounted fuel tanks also work and suffer the same burden, price. Pusher pumps have merit, also. The best solution must be the one that is simple, works, and is cost effective. Sure, given unlimited resources the solution could be had immediately. Unfortunately, I doubt that any of us is in that enviable position.
I very much enjoy the discussion.
3-5 psi is about what we pressurize the engine to though the blowby when doing the KDP jig repair. The only people I know of who have blown any seals have ran the pressure up to 30+
