Engine/Transmission (1998.5 - 2002) Cummins Service Bulletin # 3379001-05
Engine/Transmission (1994 - 1998) What is a Hybrid Turbo ??
Engine/Transmission (1998.5 - 2002) How to remove fan???
Guys Lets stop beating a dead horse on the WASTE MOTOR OIL ISSUE. .
Get a copy of Cummins service Bulletin 3379001-05
Topic: Fuels for Cummins Engines...
It contains everything you always wanted to know. Oo.
http://dodgeram.org/tech/dsl/Facts/91specs.html
#1-D Diesel or #2 Fuel Oil (diesel) only.
Under emergency conditions, 1K & 2K Kerosene, Jet-A, Jet A-1, JP-5, and JP-8 may by used if 5% lube oil is added to the fuel. DO NOT run the VP44 Injection pump on these alternate fuels without the lube oil - pump damage is likely without a lube additive!
Maximum Exhaust Temperature and Turbocharger Boost Ratings
Maximim Allowable Exhaust Restriction: 6" Hg
Maximum Intake Restriction 25" H2O
Ram Exhaust Temperature Specification
Pyro Probe Location Max Temp At Rated Power Max Temp At Torque peak
exhaust manifold 1250 Degrees F 1250 Degrees F
exhaust elbow below the turbocharger 950 Degrees F 810 Degrees F
And where does that mention mixing in waste oil? Black Diesel is kinda old news, issue is possible contamination with fine particles frome everything I have been able to find out. I usually just dump what comes out of my CTD right in the tank, no problems so far... .
Sorry there is no link that i know of, you must call Cummins tech support and they will mail you a copy.
And please dont post outdated information that is potentially inaccurate (johncammeron) .
take care all
