LOCATED IN OREGON.
A perfect rig to travel through South America and Canada.
Look up the weight restrictions on GVWR and especially in Mexico.
This rig should not get hassled like a 2500 or 3500 truck would.
1983 Chevy Suburban Silverado 4x4,
Originally a GM 6.2L diesel with manual,
Swapped to a Cummins 5.9 turbo-diesel,
Previous owner had motor rebuilt by Cummins,
New rods and main bearings just because,
New injection pump and bigger injectors,
Much more rebuilt and replaced as needed.
Only needs 1-wire to the starter,
Then it keeps running mechanically,
Has a manual fuel shutoff valve with cable in cab,
Starts up in half-second with 1 good battery,
Has two Interstate deep-cycle batteries,
Resistant to EMP and can be roll started,
Very simple motor, very reliable, easy to maintain.
Rebuilt Dodge NV4500 HD transmission,
Newer HD clutch and flexplate,
New clutch hydraulics and lines,
NP205 transfer case, the only gear-drive one, bulletproof,
Newer Superlift 8-inch springs and driveshafts,
ORD spring hangers and greasable bolts,
Dana 60 King Pin axles front and rear with 4.10 gears,
Nice 18-inch MotoMetal wheels and hubs,
Cooper SST 37-inch M+S tires at 95% tread,
New front and rear brakes: rotors, drums, shoes,
Rear Airbags with external fill nipples,
HD Tow package welded into frame,
This truck is setup up to tow very well.
Highly desirable indestructible square body Chevy,
Fully bed-lined in black so it will never scratch,
Billet custom grille with fog lights behind it,
Ultra brand aluminum running boards,
Original Silverado interior in good condition,
New carpet, very nice 2nd and 3rd row seats,
Even the rear window rolls down!
- Can use a bottom cover for the driver's seat,
- Needs driver's window motor replaced,
- Windows need tracks cleaned to slide better,
- Needs some dash wiring and to extra gauges,
- Could use minor details on the interior.
Clean Oregon title and good tags,
And you'll never need to take it to DEQ,
Runs and drives good.
$19000 CASH OBO
The good ol' 12-valve mechanical motor needs absolutely no electricity except to starter, can be push started, immune to EMP and perfect for emergencies, simple and reliable, NEVER NEEDS DEQ, better fuel mileage than newer computerized trucks, maybe slightly less power stock, but far more reliable, still can be turned up to crazy power levels, people drag-race these 12v motors, easy to build up to lots of HP if wanted, easy to maintain, easy to fix, great for towing, great for offroad, yet fun to drive on the street, has Dana 60 1-ton axles, can haul serious weight, pretty cheap insurance, it really is an awesome truck all over, this is the one to get!
$19000 CASH OBO
