A front page article in the August 18, 2008 edition of Transport Topics is entitled: "Cummins Inc. Reverses Course, Will Use SCR for 2010 Engines"
The article quoted Jeffrey Jones, VP of sales and market Communications for Cummins who said: "Our SCR system will deliver up to a 5% increase in fuel efficiency over today's solution, and that was the most compelling reason to make this change. "
The article primarily addressed larger Cummins diesels used in heavy duty big rigs, but in my opinion it would not be surprising if this solution (SCR) also filters down to the smaller diesels used in Dodge pickups.
As problematic as the emissions equipment has been on the Gen 4 engines, if it could effectively be supplanted by the addition of a Urea tank and spray system and result in the removal of the EGR nonsense, the cam profile that won't fully scavenge the cylinder of spent gases, and result in improved fuel mileage of 5% (I think it would actually be more than that on these smaller engines) I think they could count me in as one favoring such a change.
I know the current system is supposed to be 2010 compliant, but if they could get the fuel mileage back up to the older 12V levels by switching to a different emissions reduction system, it seems to me that most folks would welcome the Urea. I believe this would be possible, especially in light of the lower rpms at which the new engines are designed to operate, and all of the new and improved support systems that are now in use on these newer models: Better pistons, improved cooling systems, higher injection pressures, more accurate timing, etc.
Further, if the competitive engines will be using the Urea systems, Cummins will almost certainly have to follow suit, just because of the improved efficiency and fuel mileage. It just wouldn't do if the Duramax's and Fords were more fuel efficient than the Cummins, which could happen if they utilized SCR and Dodge/Cummins did not.
