Cummins Valve Cover
Amsoil not API certified
Just saw an ad for
Installed my Cummins valve cover the other day... I love it! I also have some "cummins red" paint, so I touched up my airhorn lettering to match.
Rob Hanson
1999 "Big Red", 3500 SLT QC 4X4 6 spd, 4. 10 LSD, Braided SS fuel lines, Mag-Hytec Rear Cover, Cummins E-Brake, Blue Box, DD3 Injectors, Banks High Ram and 14cm Wastegated Turbo, All-steel Cowl Induction Hood, Cummins RED Valve Cover, Rhino, Rosewood Kit, Scotty System, SportComp Gauges, TorkLift SuperHitch, Tekonsha Brake Controller, Rear Flood lights, Cobra CB, DeeZee Running Boards, BD 2WD Low kit, Air Lift bags and a Geno's "I tromped a Ford" decal. Member of BOMB! (WW NW Chapter)
MyPics.com (pics updated 10/14/00)
I'd rather be... .
Cummin than Strokin.
LOOKS GREAT ROB; IT JUMPS OUT RIGHT AT YOU #ad
2001. 5 2500 DARK GARNET QC LB 4X4 6SPD HO 3. 54 EVERYTHING BUT THE COWHIDE
Rob-how much is just the "HIGH-Ram" intake. Did it make a big diference in egt or spool up. If it didn't, and not too expensive, I think I would buy it for looks alone.
Looks awesome Rob! The color of the Cummins valve cover matches your Flame Red Ram almost exactly. #ad
I see you painted the "Banks High-Ram" lettering on your manifold. Sweet!
JKloppe. . I paid $250. 00 for the High Ram and $101. 00 for the valve cover. They both bolt right up.
I did not dyno, but noticed no appreciable difference in anything with the new high ram. It was purchased for looks. I liked the curves and the lettering.
Rob,
Awesome looks, #ad
Do you have a point of contact for that killer valve cover, and will it fit a 97 ?
Scott,
1997 Dodge Ram 2500 HD / Club Cab, Cummins Turbo Diesel (silencer ring removed), 4. 5" Skyjacker Double Flex suspension lift, 36x14. 5"x16. 5" Ground Hawg radial tires on 16. 5x9. 75 Weld Super Singles, dual steering stabilizer, 4. 10 precision gears, 33-tooth Speedo gear, Rhino liner, Grizzly double bent nerf bars, Bushwhacker flares, Kanduco grill insert, Confer super skid axle truss, DT Trac-bar, Moog tie rod system, Fabritech Traction bars, Energy sway bar bushings and end links. Truck Pic's
Please post a part number and contact info for that High Ram Intake!!!!!!...
Another GOTTHAVIT!!!!!
250. 00 is a bit high... but then again so was a $35,000 truck!!!!
I've already done the valve cover... that intake completes the look!!!
Larry
I will have to get that info tomorrow... I have also been approached by a member to set up a group purchase, which I will check on tomorrow.
I will post any info I get!
My 99 has a Cummins valve cover also in that....
I took a belt sander to the Dodge lettering and ... Presto... just a shiny piece of Aluminum where it used to be.
