Curiosity - transmission cooler lines at the cooler
exhaust brake and power chip
How do y'all clean the plastic cover to the factory gauges?...
Anyone had them come off and or break? My understanding its a crappy design problem? I can tell you this it will put a damper on your day when your on your way to work at 1030pm and your sitting on the side of the highway :D
Cost me $100 in aftermarket stuff to repair it. But was told I shouldn't have any more troubles with it.
Apparently the design has changed now and the stuff from the dealer is around $500... ... ... just as info.
Kat, I didn't have any trouble up front by the cooler. I did have problems with the hot transmission line coming out of the transmission. It cracked in the first bend out of the transmission. Had it brazed, to get to stealer. I was headin up to devils tower from Rapdi City, SD for a day trip and was solo. Good thing I had the DD trans pan. I might of had bigger problems. Never saw temps to tell me anything was wrong. :D I just noticed it when I stopped to fuel back up. Oil was all over the bottom of the truck and up the tail gate. :eek:
That was at 32k now at 44k. No problems since.
