current lift pump Numbers????
GEAR OIL
It's Here, It's Here!!
What is the most current numbers for the lift pump. Mine needs to be replaced.
Thanks, Ron
1999, 3500, 6x6, slt, auto, 3. 54, Qd cab, ISB cummins, towing 2001 26RKSS Tahoe 5th wheel, 1999 120hp 1800 bayliner.
thats interesting towpro , i had metal flakes in my housing also on my first filter change , i had what looked like sand in my last after 24k miles #ad
Replaced my lift pump two weeks ago.
Cummins part number... . 3938435... . Date... 15-Feb-01
Number on the actual pump..... 84351B07A
Gary... ...
Got mine done last month. Rev C (there will be a C in the part number torwards the end)
When I first got my truck, there used to be metal flakes in the fuel filter when I changed it, but over time it stopped. Now I have a new lift pump and the metal is showing up in the fuel filter again! Guess its comming from the lift pump.
Thanks, Ron
  • 98 ISB,QC,5spd,2wd,3:54lsd. Stock with BD brake and Gauges!
  • 2000 Terry 305G 5th wheel
What year truck? I think the pumps changed in 2000 from the earler ones, not sure. Mine ended in a C on the part number I think.
Gary... ...
