Munger177 said:Does anyone know of any companys off hand that make custom stainless or poly fuel tank? I'm looking for one to mount under my tool box... ... . roughly 4" tall x 20" Deep X 56" wide?
I too have a TransferFlow toolbox tank combo,plus I have installed six others for friends and family. They make a first rate,top quality product. Spendy but in my opinion worth every penny. If you are remotely handy you can do the install yourself because the directions are great and every piece you need right down to the last wire tie is included. These are not a one size fits nothing deal. I am not affiliated with TransferFlow just an impressed customer.jdwroten said:I have the Transfer Flow and endorse it strongly. I don't know the other one, but the TF requires few mods to the stock fuel system. It pumps fuel into the OEM tank as needed. So if the TF ever breaks, you can still use the stock tanks as you do now. I had an aftermarket company install mine, which is linked from the TF web page.
TransferFlow provides you with a replacement filler neck which has a port that faces the TransferFlow tank.CGeer said:how does the Transfer flow tie into the main fuel tank (2004 dodge diesel dually)
dezeldog said:I plumbed mine into the stock vent line after I did the vent mod from spooled up. Works great. I also put a 2mic racor in the line to the stock tank to filter all the fuel. Now I always fill the aux tank and just let it gravity feed through the 2mic into the stock. Works great so far.
Jim
