Custom Hood Detail
spray on bedliner
Quieting quad door squeaky easy
After looking my 2001 over I have decided to do something to the hood. I would like to put the '70 challenger RT hood scoop assembly on it but can't find anyone who makes one. I would rather use Steel but as a last resort would consider fiberglas.
I thought about cutting the section from a '70 RT hood and inserting it in my hood but that would take a lot of thinking.
Any of you Body shop types out there have any ideas ????????????????
2001 6spd, 2500, loaded. Garnet Red. Bed Liner, Chrome Rail guards, Stainless wheel flairs (small) and Splash guards. Extra Class @ 20wpm Ex SWPL member ex 70 Cuda, Black, Hemi Trans and Hemi Suspension 440 6+ (Kick myself for letting it go).
The exact hood you envision can be found at www.aarqualityfiberglass.com
'99 2500 ST 4X4, 5spd. , 3. 54, black/drftwood, camper pkg. , carpeting, rear slider, air dam, DC diamond plate running boards and rear flaps, Jacobs E-brake, Draw-Tite reciever, Tekonsha Voyager, 2wd Lo Kit.
Check out the Air Bulldog induction hood! This is the ONLY true forced air induction system (including hood) for the Cummins powered Ram. I have had mine since the beginning of July... and love it! #ad
See a pic of my hood (click "Dodge Cummins", look at the left two pix, third row up from the bottom of the photo album) http://albums.photopoint.com/j/AlbumIndex?u=188417&9=1379482
The Air Bulldog induction hoods can be seen in issue 29 of the TDR, pages 123, 124 in the TDRelease column. Awesome hoods! #ad
For more information regarding the Air Bulldog induction hood system contact:
Doug Hofeldt (designer/builder)
hofedoug@ida.net
or (208) 232-2469
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps, Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, VDO Vision gauges, Dynamat, '00 Sport grille & valve cover, '00 Sport headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake and TorqLoc, Prime-Loc, Amsoil Dual Bypass, Optima yellow tops, Bosch 275s, VA CPC, (censored), Banks 14 cm2 turbine housing/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , BD V10/Cummins hybrid TC & valve body, BD trans. front pump & PressureLoc, Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
[This message has been edited by John (edited 09-14-2000). ]
I'm not a fan of fiberglass hoods, I have a steel cowl induction hood from Reflexion, but I would advise against cutting you own hood. There is alot of reinforcement on the underside that might be lost when cut. If you do go that route, make sure you find a way to reinforce the hood, or it will look like one from a mid 70's Chevy pickup.
98. 5 3500 QC 4x4, Driftwood/Mist Grey, 5 spd, 3. 54, 19. 5 Alcoa's, 245/70-19. 5 Michelin's, Ranchhand front bumper, Ranchhand rear bumper, Ranchhand toolbox, "Scotty Air", TST PowerMax2, Autometer Gauges, Centerforce clutch, Upgraded fuel lines (JRE and Aeroquip), MagHytec Diff Cover, PacBrake
I had a 95 Chebby like that, Jeff. I have to admit, though, that was about the only thing I found a problem with - no brakes or steering or . . . BUT no Cummins!
Here is an image of the hood John was talking about (his own hood!)... maybe a bit easier than following the links... .
Rob Hanson
1999 "Big Red", 3500 SLT QC 4X4 6 spd, 4. 10 LSD, Braided SS fuel lines, Mag-Hytec Rear Cover, Cummins E-Brake, Blue Box, Bosch 275HP injectors, All-steel Cowl Induction Hood, Rhino, Rosewood Kit, Scotty System, SportComp Gauges, TorkLift SuperHitch, Teshonka Brake Controller, Rear Flood lights, Cobra CB, DeeZee Running Boards, and a Geno's "I tromped a Ford" decal. Member of BOMB! (WW NW Chapter)
MyPics.com (pics updated 8/21/00)
I'd rather be... .
Cummin than Strokin.
